Search the forum,
Discuss Advice on testing . . . please in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
V
vickery1971
Hello All,
I am after some advice as I have the opportunity to do some work (upgrading old consumer units) on a couple of empty flats for my next assessment. The trouble is I have never done a Board change in flats before (as I am only a novice), and as usual they are sub boards running from split three phase supplies via old metal box isolator switches with 60A fuses. The cable from the isolators to the boards is 10mm T&E and from the look of it someone ran a 10mm earth to each board too.
My questions are, how do I go about testing ze (it’s a tncs system) as all the earths from all the flats go to a Henley block in 10mm then one 16mm back to the service head, obviously I wont be able to cut everyone’s power to take all the earths out to avoid parallel paths, so any help here would be greatly received?
Next thing is my MEC to the board will only be 10mm, is that a strict no-no or do I just write that on the cert?
Thanks in advance for any advice you can give.
you could just do ze at main and r1 and r2 to each flat and add together, this is above me in expierience but but but but i could be right...
and only... hang round for bit, you might get better advice i was a novice and only progressing... so tread carefully in what i say...
Your EIC should just be concerned with the job your doing and so filling in the form should reflect that. Your changing a CU in a flat and that is it, the mains coming into the flat is not your remit and so you do not have to do anything concerning it. Providing there is no obvious signs of damage to the sub main, and your not adding to the loading, which you won't be then just change the CU and do the tests on the flat installation.
As far as the ZE is concerned you do not have to measure it, you can obtain that either by enquiry or calculation. Calculation will not be possible and I doubt enquiry will so I would do a Zs/Zdb, leaving the earths intact and note on your SoTR what you have done, and write on both the EIC/SoTR for Ze the Zs/Zdb and result.
yep...Zdb here malc.....
OK gents, thanks for the advice, just me worrying and over complicating things as usual. I will note that I have done Zdb instead of Zs on my EIC and SoTR and see how it goes. I am basically trying to do different things when im assessed each year as I figured if I don’t try different scenarios then I wont learn . . . . fingers crossed!
Just a quick question on the 10mm T&E with 10mm MEC . . . I take it I just state that on the cert? . . . or is it perfectly ok?
Thanks again for the advice!
Reply to Advice on testing . . . please in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi, just looking for advice. Ive been to look at a Fire alarm install job. While checking where i will take my supply from. 3 phase sub board, i...
Hi All Happy new year to all! First post but long timer lurker, so thanks for all the previous help! Just wanted to clarify something I have...
Doing a kitchen job for my daughter’s music teacher, who also happens to have been in my wife’s class at school. Nothing big… just a little...
I'm after advice on how best and safely to do a friends Fuseboard upgrade. Current setup is a Wylex 6 Way board with MCBs of 2x 6A, 2x 32A and 30A...
