Discuss Advice please in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi I have two different panels I want to connect to an MTTP controller
Panel 1
VMPP 26.4 IMPP 4.55 VOC 32.8
Panel 2
VMPP 19.3 IMPP 5.18 VOC 22.9
From my poor calculations a parallel connection would give slightly more watts but would the higher VMPP panel damage the lower one or would a serries connection be better for the MTTP controller.
thanks
Reply to Advice please in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Hi there, I just purchased a sailboat and its electrical system was put together in questionable ways.. It came with an 815W array of mismatched...
A question/advice requested re: solar panels (the context is a van/motorhome conversion)... I've got a question re: fusing/breaker for a solar...
Hi folks, A relative of mine has recently brought a small flat and needs some heaters installed. There is no gas supply to the property so...
Hi guys, Hope i could get your help and advice please . I have indesit HGM61X coocker hood and i believe the fuse is blown because of the blown...
30K
advice needed please if anyone can help I have a three phase generator on site that is going to power up one of our machines, the cables that are...
