A ashdog Feb 22, 2009 #1 Hi guys, when using plastic conduit is it ok to run power and lighting cables in same conduit run?
M megaman83 Feb 22, 2009 #2 yes that is fine although it maybe a tight squeeze if pulling a seperate circuit for each which you would need to do.!! its only low voltage cabling such as CAT5 that should be kept away from 230volt power ( at least 50mm ) to prevent interference
S Spudnik Feb 22, 2009 #3 You should also take into consideration, grouping factor when you are designing the circuit layout.
J johnnyb Feb 23, 2009 #4 Just make sure you dont mix the circuits say you had tubed a ring main with conduit and you had 4/5 d/so on that conduit you cannot run another circuit through those d/so,s . etc
