I haven't got a copy of the BGB at home feel a it annoyed with neighbour who got a plumber to do her electrical work thought some clear sparks would help out so I could go round and spout off the reasons why the plumber a installation is wrong
So you have decided it's wrong, told her it's wrong, but cant say why it's wrong, and want the forum to tell you why it's wrong when you don't even know why ?
I know it's wrong it has no mechanical protection not labelled up in the board no test cert just wanted to check if the use of flex for a power circuit is acceptable
Well, if it's been done as you suggest then the plumber has created a new circuit (even if it's spurred off an existing MCB) by virtue of it having different characteristics to what was before, therefore it's notifiable under Part P. My pet plumber passes me ALL his electrical, likewise he get's ALL of my plumbing....it's how life should work!
Why would a flex need mechanical protection in this instance any more than a T&E. Are you proposing to run this circuit in SWA or an earthed conduit system?
So it's not adequately supported ? Ok there's our starter for 10. Is this easy to remedy ?
Why do you think it needs mechanical protection ?
lol...
to the O/P:
nothing wrong as such with it....
a bit rough yes...but...
i assume additional/fault protection has been applied here?
Ok the mcb is not labelled the cable is not supported or protected and it has no test cert that's why I advised she got a part P electrician to have a look a sparks turned up and said the install was ok ?????? Wanted a second opinion
I would have thought that mini trunking is a form of mechanical protection albeit not as effective as steel conduit.
well...
one good kick and its off that wall....isn`t it....
- - - Updated - - -
so...was any testing carried out on it?
both the bits i have highligted would only constitute a 3 anyway...
Whether it complies or doesn't comply, when you see that a multi stranded flexible cable has been used as a hardwired power installation in a domestic property, ...You just KNOW that it wasn't installed by any electrician you would put any trust in!!
This is what you would expect to see from a DIY householder, not a qualified electrician that's being paid to carry out a job of work!!
