What good is a extension lead cut in half?
I'm sure I read somewhere in the BGB that the length of flex is limited to 3 meters. IE from spur to appliance only. I may be wrong
, is playing on the back of my mind as to this ! Whether it complies or doesn't comply, when you see that a multi stranded flexible cable has been used as a hardwired power installation in a domestic property, ...You just KNOW that it wasn't installed by any electrician you would put any trust in!!
This is what you would expect to see from a DIY householder, not a qualified electrician that's being paid to carry out a job of work!!
With you eng all the way!!! Is this what the domestic front has come to?.
Totally agree, there are 2 points to this thread though. The OP asking if it is legal, the answer as my post above this, the second whether good practise, The answer=No it stinks and I agree with E54 also.With you eng all the way!!! Is this what the domestic front has come to?.
My reply was basically for around 5 or 6 earlier posts M8 not yours directly, however regarding your Grammar? Pretty good Fella, well compaired to mine anyhowThanks Mike , but this is more to do with the length allowed if contained in appropriate flexible containment !?
Well that is what I was trying to get at anyway , but I suspect my bad grammar confused you :jester:
Thanks anyway mate :biggrin:
extension lead is not a fixed applianceBetter let all the wholesalers, DIY sheds and other electrical outlets that they can no longer sell extension leads or drums of flex anymore then.
no were not.Oh come on lads and lasses were slitting hairs aren't we?
