Discuss Air Source Heat Pump Signal Flex in the Central Heating Systems area at ElectriciansForums.net
Dan59H
On Air Source Heat pumps there is a signal flex going from the Pump all the way to the Cylinder,
It's 0.75mm Flex and I'm getting two opinions about whether it can be run in containment (YT2 and 20mm conduit) with the feed.
The spark is saying that it can on 5Kw pumps (2.5mm T&E for the feed) but not 8.5Kw (4.0mm T&E) and the designer is saying because of harmonic interference that it must not be touching a live feed at any point on the run. Which is nigh on impossible to achieve except cosmetically.
Any thoughts?
You should be able to get YT2 as a split trunking which would satisfy separation requirements. Conduit is a different matter but as Justin says if the cable is screened it shouldn't be a problem.
Reply to Air Source Heat Pump Signal Flex in the Central Heating Systems area at ElectriciansForums.net
We have just completed a self build, and heating system is Air Source Heat Pump, unvented HW cylinder, Buffet Tank, all Vaillant equipment. The...
My mother moved into her three bed home in 1960 and it had underfloor heating in the living room. I remember we used it when I was growing up in...
Hi guys We are due to undertake a new build install where they are using air source. Its the first air source I have installed so need a bit of...
Wiring a new extension and the clients are having Air Source Heating in their house, I'm waiting to see what supply is required for it from the...
4K
In a few days our local HVAC company will replace our propane furnace with a Mitsubishi heat pump (PUZ-HA42NKA1) and ducted air handler...
