I like an analog meter for watching a moving variable like an analogue sensor as a moving needle is much easier to follow than a digital number that is always changing
I also use an analogue IR tester for standard IR testing, apart from analogue being what I was taught with I just find it easier to see trends and anomolies that might give clues to what the fault might be.
I was quite surprised recently to see that Chauvin Arnoux and Megger and even Hellermann Tyton are still selling hand cranked insulation testers brand new. I thought they wre all obscelete donkeys years ago.
I was once looking for a fault in a basement,with the needle going all over the place.I found that if i set the meter to 1000v and locked the button in place then i could actually hear a crackling from somewhere,.I followed the sound to a damp looking joint box and sure enough it was arcing inside making a load crackle.I have found a few faults like this over the years.It pays to use your ears to fault find(but could prove painful if you get too close :-) )
