What about unistrut 90 degree brackets. I’m assuming that y’all use unistrut. Good luckWant to install a Ring Floodlight Pro at an angle (say, at almost right angle to wall). Is there a suitable 90 degree bracket that might suit this. Weight of the flood light is about 2.5kg.
Thati s the one. Can manage the ladder bit - it is the bracket I have problem findingPossibly need something ad hoc
Builders merchants may be able to get heavy brackets and fixings for steel joists. Otherwise angle iron and someone with a welder.
Those ring floodlights are too heavy if it’s the same one I’ve fitted. Big round housing, two spotlights and the camera?
Not easy when you’re up a ladder.
There are a few heavy duty swivel brackets around that will turn to more or less 90 degrees, for example:
Swivel Bracket for LED Floodlight up to 10kg - Buy Now
This swivel bracket from KR Products can mount 1 x 10kg LED floodlight. This product has an impressive 3 year warranty and is made from durable steel.www.bltdirect.com
See also the KR Products website, e.g:
Wall Mounted Archives - KR Electrical
KR Products manufacture and supply an extensive range of wall mounted brackets. They are all designed with a swivel feature that allows horizontal adjustment to direct light where required. They are universal brackets and as such are suitable for floodlights from a small 10W LED up to the more...www.krproducts.co.uk
This sort of thing is widely available.
I've linked Toolstation as they have loads of stores, but most wholesalers should keep something similar.
Floodlight Bracket
Floodlight brackets offering a choice of swivel, corner and pole mounting.www.toolstation.com
Nope. This is a corner one. I need one for flat wall
