Discuss Angle bracket for a floodlight in the UK Electrical Forum area at ElectriciansForums.net
Want to install a Ring Floodlight Pro at an angle (say, at almost right angle to wall). Is there a suitable 90 degree bracket that might suit this. Weight of the flood light is about 2.5kg.
Possibly need something ad hoc
Builders merchants may be able to get heavy brackets and fixings for steel joists. Otherwise angle iron and someone with a welder.
Those ring floodlights are too heavy if it’s the same one I’ve fitted. Big round housing, two spotlights and the camera?
Not easy when you’re up a ladder.
What about unistrut 90 degree brackets. I’m assuming that y’all use unistrut. Good luck
There are a few heavy duty swivel brackets around that will turn to more or less 90 degrees, for example:
See also the KR Products website, e.g:
Thati s the one. Can manage the ladder bit - it is the bracket I have problem finding
I think KRP16 should work - takes upto 5 kg. Thanks.
This sort of thing is widely available.
I've linked Toolstation as they have loads of stores, but most wholesalers should keep something similar.
Reply to Angle bracket for a floodlight in the UK Electrical Forum area at ElectriciansForums.net
Hello I’m going to install a hard wired 230v security camera, incorporating floodlights, outside and above garage door onto brick. An exposed...
Cheers everyone. I'm here trying to install a pair of outdoor R7s floodlights and reading the manual (who does that? I do.) it mentions multiple...
I had a call to a new customer who was experiencing what sounded like nuisance tripping on a kitchen ring. Some background first. It's an MK LN...
Hi all. We have had 7x 400w solar panels for a number of years now on our roof which is se/nw facing end terrace. 4 on se side 3 on nw side...
Hello everyone, I hope someone can kindly advise on an issue I'm having. I had an Electrician install a couple of these hardwired ring...
