Not on the island @JBW175 bloody miles apart....
That’a absolutely disgraceful planning mate, just to rub in, we’ve got Wall Dogs in stock....?
although I still miss going out on Albert & Palmy road, so you win that one. ?
Is that the Island of England or the Freezer food outlet.
I’m pretty sure that he’s on about the isle of Portsea, and not to be confused with those 6 fingered webbed feet people from the IOW.
EDIT, no offence meant for any 6 fingered banjo players from the Isle of Wight that dabble in electrics.
The colloquial term for them is caulkheads mate.......don’t ask me why ?‍♂️?
I never knew this, but I’ve got a couple of mates off the island so will start using it as a term of endearment for them. ?
Another update to this thread, regarding the longevity of the metabo triple blade.
It's done a further 3 rewires now. The triple blade is removing the chases just as well as when I first started using it. Not entirely sure but I would guess at 5 rewires in total so far over the 1.5 years I've had it.
It is awesome. A standard chase for a socket (approx 2m), takes around 15 - 20 seconds, leaving a perfect chase.
Both use 125mm blades, with 22.23mm centre.
I've looked into this a few times, but never found a definitive answer..
How hard are the walls you have been using it on?
They have all been either red brick or stone. They do have a varying depth of plaster on them though, so you are not just going through the brick or stone at full depth. I set the depth to 20mm, this is perfect for 25mm oval conduit which sits snuggly into it and only needs 2 or 3 screws to keep it secure.
So far it does seem to have gone through anything. If the surface is a bit harder, you just go more slowly.
I was certain I'd read a reply from metabo saying you can't use it on the mfe30, but I may be wrong. Best thing for @mattg4321 to do is to contact metabo to be sure.
