B
Baddegg
Not on the island @JBW175 bloody miles apart....They are in Havant, but I can’t speak for the rest of Portsmouth, the south coast, or indeed, the rest of the UK ??
Is that the Island of England or the Freezer food outlet.
The colloquial term for them is caulkheads mate.......don’t ask me why ?I’m pretty sure that he’s on about the isle of Portsea, and not to be confused with those 6 fingered webbed feet people from the IOW.
EDIT, no offence meant for any 6 fingered banjo players from the Isle of Wight that dabble in electrics.
?I never knew this, but I’ve got a couple of mates off the island so will start using it as a term of endearment for them. ?The colloquial term for them is caulkheads mate.......don’t ask me why ??
I'm almost certain it doesn't I'm afraid.Anyone know if the triple blade fits the MFE30?
How hard are the walls you have been using it on?Another update to this thread, regarding the longevity of the metabo triple blade.
It's done a further 3 rewires now. The triple blade is removing the chases just as well as when I first started using it. Not entirely sure but I would guess at 5 rewires in total so far over the 1.5 years I've had it.
It is awesome. A standard chase for a socket (approx 2m), takes around 15 - 20 seconds, leaving a perfect chase.
They have all been either red brick or stone. They do have a varying depth of plaster on them though, so you are not just going through the brick or stone at full depth. I set the depth to 20mm, this is perfect for 25mm oval conduit which sits snuggly into it and only needs 2 or 3 screws to keep it secure.How hard are the walls you have been using it on?
I was certain I'd read a reply from metabo saying you can't use it on the mfe30, but I may be wrong. Best thing for @mattg4321 to do is to contact metabo to be sure.Both use 125mm blades, with 22.23mm centre.
I've looked into this a few times, but never found a definitive answer..
