Discuss Any ideas what this is and if I can get a replacement? in the UK Electrical Forum area at ElectriciansForums.net
2 wires have broken off leaving 2 still connected.. it is in a switch for a table saw.
Upload the image directly to the thread: The most awesome images on the Internet - https://Upload the image directly to the thread.com/6ig2hSn
the 2 squiggles terminals are the input. that's from the supply side, either way round. the + and - need to be the correct way round. if that's any help.
Reply to Any ideas what this is and if I can get a replacement? in the UK Electrical Forum area at ElectriciansForums.net
I have a Firebird oil boiler that is controlled by a Honeywell timer (no thermostat) that has channels for hot water and central heating...
I would like to reuse a 10mm cable to provide a ring circuit in an area. The cable is currently used for an electric shower, still connected at...
Evening Gents just after a bit of advice and what would you do differently. I have wired up 3 kw heaters in 4mm tuff cable (40 meter distance...
Hi, I replaced an outdoor electrical socket recently with a 2 gang, BG socket which has LED lights to show when it is switched on. Since then I...
