Discuss Any recommendations for some cable shears? in the UK Electrical Forum area at ElectriciansForums.net
HappyHippyDad
I want to be able to cut through tails more easily. At present I am nibbling away at them with my side cutters which takes time and also doesn't leave a very clean cut.
I borrowed the builders cable shears and they literally just sliced though 16mm tails quickly and neatly. I have a set of bolt cutters but these are too big so I was looking for any recommendations on a set of cable shears?
Cheers all
https://www.amazon.co.uk/KNIPEX-95-...11&hvtargid=pla-422663569583&psc=1&th=1&psc=1
They will breeze through up to 25mm. I have had the yellow and red handle ones 10 years but cant seem to find them
I did see those but they just didn't look very big. Not very long or a wide mouth to get 25mm in. Do they definitely cut 25mm? These look bigger as if they would do the job better.. https://www.amazon.co.uk/Yato-YT-1969-YATO-Cable-Cutter/dp/B008YN40D8
I have CK and Knipex , both cut effortlessly
Could you post a link to them please Ruston?
I had an old pair of orbis will (knipex) cable shears which previously belonged to my dad.
They were pretty good and chomping heavy gauge cable.
But over time got blunter and blunter.
I now use a ratchet cutter which is very good and ripping through tails and small armoured cables
I use simple Bahco croppers. Sharp as a gin and tonic after years of use. I think the CK versions are supposed to be identical in style and quality. Probably same factory.
I can't find the CK exact ones , very similar to these .
As @Dobes_88 The knipex Installation pliers are very good too , but are only recommended up to 16 mm .
The CK of the link I have posted do two sizes , 16mm and 25mm.
https://www.amazon.co.uk/C-K-39064-RedLine-Cable-Cutter/dp/B002JCTIOG
I was in a rush and needed some like yourself i was cutting tails with side snips ... 2 years later still got them and my goto cutters for tails
https://www.NoLinkingToThis/p/magnusson-cable-wire-cutters-8/2058v
Reply to Any recommendations for some cable shears? in the UK Electrical Forum area at ElectriciansForums.net
Hello. I'll apologize to start with as due to my lack of knowledge on the matter I'm likely to waffle a bit and call everything by the wrong name...
Hi, I'm interested in a house built around the 1980's in Northern Ireland. I took a few photos of the consumer unit etc. which is situated in the...
  • Locked
5K
Using a 'power to the switch' method. At first I had a raft of issues, but by following these steps I was able to solve those issues and with some...
I have a fairly typical setup of the light on my landing being able to be controlled by both a switch on the landing and a switch at the bottom of...
