Discuss Any tips on lifting glued down chipboard? in the UK Electrical Forum area at ElectriciansForums.net
So. Having brought a new house the misses now wants downlights. Not an issue. Only snag is the boards aren't screwed they are glued down. I've done a few new builds but everything is wired from below so how is the best way to lift the boards? Is it just a case of expect to replace what you have to lift? Will it come up at all? Will I spend weeks scraping glue off the joists?
Glued chipboard is an absolute nightmare, just get the floors all replaced with floorboards!
Expect a lot of breakages, if you have the web joists then be careful not to damage them. If you can get one section up then it may be possible to lever the edges along the joists from below the floor and break the glue line, alternatively a multitool can cut the glue through slowly and laboriously but will probably cut into the floor (not the joist) as well.
It may be easier to replace the ceiling or cut large holes in the ceiling to allow you to drill the joists and then repair the holes cut.
It's going to be fun explaining that to customers in a few years when they want work done. "Sorry but I'm going to have to butcher your ceiling to pull some cables." Who makes up this stuff. Oh yeh. People that don't have to work with it.
Fitted 9 downlights in one which had tongue and groove, glued down and nailed (3") chipboard onto some sort of thin metal beamed shell that had thin ply-board between these wide apart beams
Took 2 hours to wire and fit the lights and about 3 or 4 to lift the 8x4 board
Good luck and keep the language down
Wire em from below, removing plasterboard or cutting access holes as required. Patch up, re-skim ceiling & paint. Probably cost you £150 of a plasterers time, some blue grit and a couple of bags of multi finish. Alternatively get her to pick out a lovely light at B&Q, but don't come on here asking how to wire it up :)
Can't understand all the fuss, come on lads. Just use a hole saw big enough to get your hand in, cut a hole in the floor above the downlight, then screw a couple of battens across each side and replace the plug you have ready made. You can easily use a long shafted spade bit to get through joists.
installing down lights in room already finished & especially with glued down floor is mainly done from below. if you pull that floor up it will squeak & never go back the same. mostly if lucky you will get the luck of the gods on one side & be able to fish cables between joists to each light & if very lucky when spacing down lights you might be next to a cable run & poke them through meaning less drilling as should get every other joist.
better would be depending on the house you might have eco beams & then well you would have all the luck bit of fiddly up down with the rods & you could be through without drilling.
best of luck, we usually use the rubber dust catchers & 100mm hole saw cut out keep, install wood either side of whole & then put piece back after wiring, less mess & should only leave a small hole in middle & the rim of cut out to be repaired.
does take me back to one of the first house rewires I undertook owner wanted to supply down lights ok no probs get the ones with individual transformers & not the ones joined to a big unit.
owner comes back from one of the big sheds & look what I got such a deal 3 down lights on one & 3 on the other, don't worry m8 we are having carpet so we can roll it back, ok I will mark up the floor board with marker pen & cut to allow access all agreed.
7 years later wife rings me having an issue with downlights they not working properly on 3 of them, that will be transformer no problem I will come over & roll back carpet locate & replace unit phone went quite for a few seconds & then the voice came back we had a wooden floor installed 3 years ago in that room.
mentioned cutting 100mm whole in ceiling & repair answer we will live with it
If after 16 years as a spark I couldn't wire up a b&q light fitting I think I'd take up plumbing ;) can't see the misses understanding the need to plaster a brand new house though. I think it's going down the cutting squares between the joists in the cupboard and putting 3x2 in to patch the floor.
best way for putting in your down lights is by cutting a square holes from the top .and start putting in your down lights. couple of battens and the way you go.
We just use a circular saw set to the depth of the weyroc, cut back to joists and fillet the sides and replace with new, glued and screwed back down to stop any squeaks, usually only need a sheet up in the middle of the room above and fish to each hole with rods, if we come across a joist we just cut and patch the ceiling, handy when all lights are in the same bays though.
Like ałl these things what you need is something called experience. It's usually possible to plan it so the lights are running down a joist length so you can often get away without wrecking the house. It's alright talking about overboarding and skimming but have you seen the mess it makes? That's if you can get a decent plasterer to get out of bed for a single ceiling. Last job I did the cupboards ran right up to the ceiling!
Loads of plasterers like doing little PJ's at the weekend or evenings. Just got to be in the know :). And you don't need to overboard. Do it all the time on kitchen refurbs, invariably 'cos the floor above has been tiled or laminated, and the current ceiling has been artexed.
In a new pad, its up to you. Floor up, or a few holes in the ceiling and a bit of plastering.
But if you've got a run say a new hob from db to kitchen thats a hole at every joist to get a drill in. You'd never justify the cost of that many plugs. Surely.
Every other joist... you can drill the joist on either side from one hole, possibly more if you can get longer drill bits/extenders on. And the cost of plugs should be covered by the time you save not having the hassle of cutting and fixing battens etc.
I suppose all the techniques and types of construction are covered on the 4 week DI courses together with practical demos that an on the job apprentice would get?
day 3, just arter lunch..... "how to butcher a chipboard floor"
day 4, 1st lesson............... "how to put the blame on wet-pants".
The trouble with drilling blind is you're going to hit any wire or pipes clipped on the other side of the joist that you couldn't see:(
Some interesting methods of accessing through the weyroc sheet
Have you ever seen a plumber gaining access when he has a leak?
I have seen that plumber on a new build gain immediate access with nothing more than a trusty hammer
Bang bang -hole,bang bang-hole :)
I also use this to repair downlight holes when they have disintegrated. Bit of 3mm ply or hardboard and use the cutter to cut a 5" diameter circle. In the centre of this circle use the required size downlight holesaw so you end up with a 5" circle with a 72/75mm (or whatever the required size) in the middle. Saw cut between the two and you can then feed this up into above the hole so that you a) have something to fill to (if required) and b) have something solid that the sprung wings of the downlight can bear on
As already mentioned, I'd avoid lifting any boards. They are glued for a reason, after you've lifted them and replaced them, they'll squeak, and you'll regret it.
If the ceiling can be skimmed after, then holes from below is the easiest, typically I use 100mm dia holes. Keep all the plugs and put them back in the same holes, with a bit of timber batten to support them.
If you want to avoid ceiling damage, then I'm with holes from the floor above using one of the cutters. Yes a kit costs £50 but a good part of that is the steel plates (£4 each), which you'll need.
I sometimes use a right angle drill that can fit through the 100mm access hole. That way, I only need an access hole every other joist. But there is the risk of hitting existing cables & pipes in the voids you can't see, so try to work out where existing cables and pipes run first. If you've already cut the downlight holes, that gives you some clues as to what is in there.
Sometimes you can be lucky and find existing holes & cables. A recent kitchen 8 downlight job, one row of lights was almost over a run of cables, I could use the existing lighting feed from the switch to pull in a new cable between several lights positions. A good cable rod set with magnet & chain is sometimes very handy.
Serious section now, as its a new build see if you can get hold of the architectural plans as then you will know where the joists are and the noggins so then can plan the cable run, when I did my flat rebuild we where lucky to have enough room to lay a false ceiling with plenty of space to run any additional cables if required.
I will add my vote to the board cutter
It's neat, quick, and can be used over and over on all sorts of jobs.
Try to avoid lifting the floor, for all the reasons already stated.
My wife wanted downlighters in the kitchen too...the bedroom above had a fitted wardrobe at one end, so I lifted the floorboards in there and BINGO the joists ran lengthways so it was an easy task to pull the supply into that space, and feed cable to the downlighter holes drilled in the kitchen ceiling, without having to disturb any of the bedroom floor itself. Replaced the boards in the wardrobe, bit of spare carpet on top, job done.
If the joists run the wrong way, then the board cutter, routabout is your friend.
Reply to Any tips on lifting glued down chipboard? in the UK Electrical Forum area at ElectriciansForums.net
The prctice these days is to D4 glue 22mm T&G chipboard together and to the joists. Then follow with nails or screws. Has anyone tried lifting...
A friend of the family recently lost her husband to the big C so I need to be careful. Every small thing is sending her into tears so when her...
Hi all. Have an issue i'd love some advice on if anyone would be so kind. Will try to be brief. Thank you!! So, have an intermittent RCD trip at...
