Discuss Anyone spot the mistake in this install? in the UK Electrical Forum area at ElectriciansForums.net
Well there is 16mm coming in but I guess there must be an external MET where the bonds are, hopefully.
I'm sure cpc in 3rd spot should've been in 4th :)
Reply to Anyone spot the mistake in this install? in the UK Electrical Forum area at ElectriciansForums.net
Hello I have some decking lights which to be fair, have been nothing but pain in the bottom since they were installed. Moisture in the lens lamps...
i have faild napit annual assessment with silly mistake of using on consumer unit type AC rcd instead of Type A rcd. i bought type A rcd but they...
Hi everyone, looking for some advice or knowledge on DNO approval. I’ve gone to sign up for export with Octopus. On the application form they’ve...
I have 16 ceiling spots to be replaced in a room being repurposed as a bathroom. Some will be over a shower, basin and bath hence need to be IP65...
Does anyone know what this is found when removing old mirrored wardbrobes
