Hi everyone,
I am looking for a way of cutting out the power supply to a washing machine when its waste pump fails due to it flooding a customer property previously.
I was thinking of putting the pump on a plinth with container below and using a water sensor or small float switch within the container so when the pump fails it will over flow water into the container which will trigger the switch and isolate the power supply to the appliance before the container overflows.
But I am struggling to find a small 240V float switch or water sensor cable. I am not an electrician and once I know what I need to do the job I will employ a qualified electrician to carry out the installation.
I have been looking at the following:
Miniature Float Switch - Triton Controls - https://www.tritoncontrols.co.uk/lr21-miniature-reed-float-switch.html?ppc_keyword=&gad_source=1&gad_campaignid=12079016639&gbraid=0AAAAACdOt02-21MiAUROLbBQgJxV6FR0b&gclid=CjwKCAjwxrLHBhA2EiwAu9EdM_tayYltouNCgOT2IB6FZtT-ZRMMxuwQ3Q9FOwLIu05u-SgFkg7uGBoCavUQAvD_BwE
This says is can do a max of 100V so not sure if a transformer can be used in conjunction with this.
I am hoping someone on here has done similar or knows of a product designed for what I am trying to achieve. It's just a small private domestic property not commercial.
Appreciate any help,
Many thanks
Many thanks
