A one off payment Tel well worth it, to get someone of your caliber
yeah but to go there and back is 5 hours + driving. not worth the OP paying for that if someone is local to him.
Hi all, I'm hoping someone has an idea what this could be as I've had two electricians round and they've not been able to sort it out.
Various things are causing the sockets in my house to trip, from the fridge door and cooker hood, to the on/off button on the coffee machine and reading lamp. It always happens when the fridge door isn't pushed hard enough and doesn't completely close, when the reading lamp button doesn't properly engage on turning it on, or when the cooker hood sticks on opening or closing (taking a little longer to turn on or off). Why would these things cause the sockets to trip and require turning on again at the consumer unit (a Memera 2000)?
Thanks in advance,
Phil
How old is your house
you need to find a sparks that's competent at fault finding. i would offer, but you're too far from the civilised world (north of birmingham) :D:D:D.maybe a member is close enough to your location to fix the problem. as stated before, a N-E fault, perhaps intermittent, or the RCD itself,is the likely cause.
I don't think Cambridgeshire is north of Birmingham Tel but I take your point it is out of your civilisation.
How old is your house[/QUOTE hopefully your wiring is of a reasonable standard,t are a number of things that it could be, any decent electrician should be able to sort this out I suggest you get another electrician to check your wiring, its the only way you will sort this out
Righto, I'll try another one.
Is this something you've come across before? It's not the appliances themselves, it only happens when their power switches don't engage properly, like how you can make a striplight rocker switch crackle.
Is your suspicion that the wiring is dodgy or the CU? The reading lamp which sometimes causes it is upstairs, so it happens on more than one ring.
power switches built into the appliences or switches on sockets etc?
if you are turning the socket switches on and off regularly, and they have never been changed then after 20 years they may be worn out.
Hi - yes, but the only one I’ve worked on was a double pole switch where I’m pretty sure the N was bouncing and that upset the RCD. I replaced the switch and it stopped doing it. In your case with multiple switches doing this I’m thinking your N and E not might be 100% anywhere from supplier cutout through to the end appliance. Changing a switch is one thing, but I think it’s time to get an experienced Electrician to test and inspect.
It's the on/off push switches on the appliances that cause the trips*; they're all left switched on at the wall. *plus the fridge door when it doesn't close fully if not pushed hard enough
I think wilko has probably hit the nail on the head, rapid energising/de-energising of appliences when the switch is arcing is probably causing an imbalance that the rcd is seeing as a fault.
I forgot to state that the appliances are new. Apart from the fridge door!, the ones that I have trouble with are power buttons such as these:
