Discuss Are lighting marshalling boxes a legality? in the UK Electrical Forum area at ElectriciansForums.net
IAmSparkytus!
Hi all,
Recently been fitting a good amount of LED panels into off licences using Klik boxes but have also had a few customers turn the work down due to cost.
I prefer to use Klik boxes as I think they're a good system and also allows the ability to isolate lights individually rather than having to turn a circuit off to replace one light if one was to go faulty.
It is, however, the cost of these marshalling boxes and klik plugs which raises the price for the customer.
My question is... What's everyone's opinions on using klik boxes as opposed to just wiring the fittings daisy chain style? Is there any reason why this cant be another option if the customer is unhappy with the price of the initial klik method?
PS. I'm referring to shops which are looking at between 10 to 20 LED panels
Look forward to hearing some feedback!
use click flow ( or similar) connectors. these allow disconnection of individual fittings. the also come in 4 pin if you have EMs on the install. hell or a lot less cost.
as above. independent isolation of each light is a matter of convenience. a faulty unit can be isolated without killing the circuit.
Klik marshaling boxes, or individual Klik roses for each light fitting are my preferred option personally.
But it partly comes down to how they are being wired?
Generally if it is a conduit install then Klik roses is the best option, one above each light.
If it is being cables with something like flexshield then the multiway Klik marshaling boxes would be my preference I think.
[automerge]1596279139[/automerge]
I've used them a lot in domestic, and in commercial where the ceiling is permanent and you only have the cutout for the light to work through.
But I wouldn't normally use them in accessible voids such as suspended ceilings, it just doesn't feel like the right tool for the job. I don't like them just hanging on the ends of cables without being fixed in place.
with suspended ceilings, all boils down to cost. if client wants to pay for metalwork and Klick roses, then that is the best option. generally a client's budget limits the job to flex laid on the tiles or maybe cable tied to the suspension wires and click flow (or similar) connectors it's his/her choice. the difference in cost is hundreds.
Yes sometimes budget comes in to it, but the choice of installation method is not based purely on cost, and not left up to the client like that.
Flex laid on tiles is a bodge and non compliant, if that's what they want then they can pay a cowboy to come and do it for them.
Plug & play, seems to be in @ the moment,& yes it can look untidy,but in this day & age,fast fix is the norm.
Personally I'd describe that as being one step up from being lasooed in and far from a good installation method.
Its how one of the buildings I have been in was done, but it was only like that in the corridors in all the rooms it was marshall boxs
I think it looks like it was done like that as the ceiling above the false ceiling is slanted made of metal and about 2 section of a tower above the false ceiling?
It doesn't matter how big the void is it is still a low standard of installation work.
down in the affluent south, you may be able to obtain jobs using the best installation methos such as Klik roses/conduit/metal trunking etc. up here it would be "how much???? you're taking the pi$$. close the door on your way out".
(i refer to retro fitting in existing properties, not new builds where the cost would have been factored into the build).
You can use basket,most containment done in a minimal way, Skeleton route, you still have to come off it,to go where you need to get.
Unlike trunking & conduit.
Reply to Are lighting marshalling boxes a legality? in the UK Electrical Forum area at ElectriciansForums.net
Struggling a touch at the minute with customers getting work done by “someone they know” and citing our quotations being too expensive as the...
BMS installers have attended. After fitting the panel they also replaced the aged lighting in the boiler room with 6ft LED battens as instructed...
I was at a customers house changing a socket and they asked me a question about their lights. Some of the lights in the house suddenly get...
Hi guys I have some industrial lighting circuits to wire in a workshop and was after some fresh ideas/suggestions as to how i could best do this...
