Discuss ARMEG EBS TRI-CUT CIRCULAR CUTTER in the UK Electrical Forum area at ElectriciansForums.net
Afternoon all. Anyone got any experience using a ARMEG EBS TRI-CUT CIRCULAR CUTTER ? Just curious as considering one or sticking with stitch drilling for back boxes.
stitch drill and a sds scutch chisel in a 110V makita. child's play.
breeze block and light concrete blocks no problem, red bricks is slow and hard going with one, if you get one make sure you get the shroud to cover the bits or dust and debris goes everywhere. have the full set and to be honest dont use it much, tend to use the angle grinder or chaser for the main cuts then sds for the chasing out and levelling off in the back.
Reply to ARMEG EBS TRI-CUT CIRCULAR CUTTER in the UK Electrical Forum area at ElectriciansForums.net
I find myself in the position of having to fit a few back boxes in to plasterboard. In the past for the odd one I just used a hand plasterboard...
I was working alongside the plumber yesterday. I had to drill some 32mm holes through joists. I always use my Makita 481 high torque drill will a...
I already have some 18V Milwaukee power tools and was looking for a circular saw for general wood bashing duties, though having a metal cutting...
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
Hi I've inherited a very tight space, a KMF switch and some split-con for a sub-main to try and tidy up. It's a joyous non-restrained single...
