The CU is stong enough to hold it and cannot fallout maybe I should just run it to the Henley terminate their and the run tails of that .its all I was asking earlier
1. You can not gland an swa of any size directly onto henleys.
2. You can not have unprotected single insulated cores.
You need to think this job out a little more. You have said that you have the SWA terminated into a plastic CU what type of gland did you use and how did you connect the armouring to earth?
Ok new people on this thread used the grey cable as earth black neutral brown live I have google this as was not sure and seen an image of how this was done .sintra can you tell me the correct way I am learning or do you have a link to this
I dont do it this way
Alert, there's been a breakout from a mental institution!
As I said to people on her earlier spark run the swa to Henley box and then run meter tails of this and used the grey as Cpc
