I didn't pass mine first time though I had no idea what I was doing so that's understandable! What that first exam taught me was The procedure of the exam under exam conditions and how much you're at an advantage if you have your own test kit that you're comfortable with. i don't know what you're like for learning from books but I found leaving my GN3 in the loo helped . little bits of info on a regular basis. works for me
Thats a good point as I do have a tendency to go from one thing to another when studying then feeling like scrambled eggs. lol.
I'm lucky enough to have my own tester so do get to practice some but am going to knock up a dead board and circuits in my tool cupboard to perform test rituals at an attempt to make it second nature. There is a socket outlet in there too and its near the working CCU so I can practice away without sending the Miss use and teenager too crazy with down time.
It's part of my ADD thing Try and shove too much in at once and it's pointless and frustrating Let it absorb bit by bit and results are much better!
I read once that the brain absorbs things better into memory if you read before sleeping.
so,
Bed for the head after you've read.
Also, one of the greek philosophers said:
Tell me and I'll forget
show me and I'll remember
Involve me and I'll understand
So yes I think hands on is the best method, it makes it far more simple.
hi marty
i agree it was hard to keep cramming all the info in as you do sometimes scramble it up, but i just kept checking things over and over then having forced breaks by looking after mrs,walking the dog for miles and lots of household chores lol washing up etc then back to reading and writing
i have bee contacted again off the lv3 2330 tutor at one of the local colleges, he says that a candidate has not completed enrolment yet and if he is not coming back the place is mine
I am a little bit daunted by it as i have not done lv2 so a little unsure of whats involved and if i will be up to it
the tutor says i should find it easier than quick courses and the 2391-10 as its a more steady pace
But I too only want to do domestic and small commercial so my main aim is to start up self employed just finding help is frustrating to say the least but what else can i do but try and try again
good luck if you do go ahead with the 2391 i was a little nervous but really enjoyed it. i did study all day every day for about 4 months at home as well as doing the 8 week evening course. i did this as i wasnt working in the game which as you say is probably the best, so all i could do was revise over and over
there is a lot to learn but its possible mate good luck with whatever you decide mate
i have been contacted again off the lv3 2330 tutor at one of the local colleges, he says that a candidate has not completed enrolment yet and if he is not coming back the place is mine
The level 3 does follow on a lot from the level 2, so there is no doubting that it is a bit harder if you have not done the level 2 first, but the style of examination is much easier than the 2391. You will find the inspection and testing parts easier than what you have already done and the fault finding is also very similar. The only really tricky part for some is
the multiple choice scientific principles paper, which also includes a lot on motors. However i am sure that you would enjoy it and there is always a lot of help on here. Is it a day time or evening class? I think the day courses are more generous with the time allocated.
hi mate I think it will be 2 evenings a week wed/thur they do both but there only may be a place on the evening if one of the candidates does not come back plus it is probably best if i do the evening as my daughters will be able to care for my mrs whilst i am there
yeah the scientific side of things and motors i will deffo need help mate
I mainly just want to do self employed domestic and commercial and will keep pushing towards starting out as a domestic installer as this is mainly what ive done but a little lost with how to set up as this will enable me to work from home as and whe around the needs of caring for my mrs
A friend of my mrs has also asked his mate who owns his own firm about any vacancies and he says he is struggling to find elecys and has given me his number to ring but i think they will probably want people who are fully qualified so i will ring and see no harm in trying eh mate think he told him i am qualified and also that i have 2391 as for first bit to a point and as for 2391 yes but not much experience
good luck with placement bruce fingers crossed you are obviously very dedicated so that will carry you to success.
on the self employ stance, as you've worked and had experience in other things I would offer those services too to help generate work flow and then as the electrical starts coming in you can taper off the other work as you see fit. Its hard for most at moment so needs must and make the most of any skills you can employ. Thats how I see it and thats what I do at mo even if I have to get someone with the needed skill set assist etc. just make sure you get your cut when giving others work as you would be the project manager. I did some painting a few weeks ago and got a rewire out of that so diversification can have its rewards.
I started advertising domestic electrical work but the response was domestic and electrical work. Someone called asking me to hang some pictures I thought ok they want to avoid the wiring. When I was there he asked me to do other things I was there 3 hours and charged £90. Not bad for on the way home and he referred me too a few months later. It goes up and down so when down you take the work you are capable of.
yeah mate
I am being asked to do lots as always but mostly for free lol
two neighbours want me to connect a outside light at the rear of each of there properties (council houses) to there existing outside oval bulkhead lights but as i am not set up wary of undertaking anything
to do this work for free as its not notifiable would i still need pli insurance first and does the council need notifying as thet are there properties
I just want to keep my hand in but legally as soon as i started to explain to her about part p, inspecting and testing, certifying and that i may have to use conduit or hi tuff as recommended by a forum member as the run will be from the side of houses to the back of the houses on both, also with me not being with a govering body it was the usual do you have to do all that just to put a light up I said yes or get a approved registered contractor as i have to have insurance etc etc
i keep turning work down as i am not registered I am going to have to just go for it and register with elecsa as its no good keep turning people away or eventually they wont ask in the future
so if I got pli could i carry out non notifiable work as long as it complies and is certified with a meiwc
ive turned another job down of a joiner mate to fit downlights in a new porch and canopy he is putting in for someone
my brother wants his existing circuits from old wylex transferring to a existing 12 way ccu he had put in about 5 years ago for a extension to his kitchen ( NO CERTIFICATE, NO labels , large holes exceeding ip4x , tails sheathing stripped back to far etc etc,) or changing for 1 new ccu tis is what i hope to use for elecsa assessment but his installation is rough to say the least. he also wants armoured to a shed with a socket and lighting circuit, garden lights. downlights in soffit over garage door
Its frustrating as i know i can do this work but a keep putting it off as i am not registered so its a catch 22
the sooner i can register with elecsa the better
i will have to get the process started or i will have spent £5000 so far and not earned a bean so i am going to ring elecsa for a great deal of advice lol and start the process
yeah mate
Why do any work for free after all the money you've spent and time training? If its a council property the tenant should ask the councils permission but most don't and just DIY. Usually councils remove them selves of maintenance with such issues. Personally I generally wouldn't touch council properties or the like but. I have done the odd NON notifiable.
I know a lady that was fed up of waiting for the council to repair her boiler in the winter too! so she paid for a new central heating system. the council treats her as though its her own property with repairs and since she has retired and the maintenance is needed and she has not got the money.
I bet they would't say anything if it was a painter or plasterer.
Go for it or how long will you be putting it off if you do get stuck you can always call the tech line.
Anyone can do non notifiable work but a council will probably find a way of charging you for altering there property if can trace you and prove it was you I thinks.
PL is always good to have.
Good luck
Best Regards
Good luck
Best Regards
Cheers marty
the only real option is to join a approved scheme and go for the assessment as i am sick of going round in circles trying to get help with start up or employment the best option i think is to join elecsa then set up doing domestic as a lot of employers probably wouldnt employ me with the quals i have thats why i am considering the 2330 lv3 if a place comes up as well as to gain more knowledge that i am lacking on science side of things and three phase cheers for reply marty
ezzzekiel,
brucelee,
