W
whitebeetle
Hi All , When assesing the suitability of fitting an RCD Controlled consumer unit on an ageing installation (i.e swapping from just an on'off incomer and rewirable fuses) whats the easiest method of testing to see if fitting RCD will cause problems with un-neccecary tripping. I.e what tests do you carry out. I cannot see how its feasible to go to a property of someone who wants a quote for a new consumer unit and have to disconnect and test every circuit before being confident of a reliable system after fitting new consumer unit ? What tests do you carry out ?
Cheers
Chris.
Cheers
Chris.
just to put it back again and tell them changing it will cause problems !
