Discuss Automated Bathroom Advice in the UK Electrical Forum area at ElectriciansForums.net
M
m4rk44
Hi.
I was hoping someone might be able to help me with regards to a fully automated bathroom i'm trying to achieve. Theres 2 things i'd like help with.
1) I want to install a mirror heater behind a tiled mirror. I would like this to be fully automatic and my theory is to purchase an extractor fan with a humidity/moisture sensor built in and T off the sensor on to a relay to operate the heated matt when shower is on/steam in room. Would this be possible and can anyone give any insight or better ways of doing so?
2) Fully automatic lights. Im basically after a decent/well working system to bring the lights on when needed. My guess would be a centralised motion sensor that stays on for "X" amount of time unless it senses movement again. Again, can anyone advise or suggest a better system and why?
I know some electrical bits and bobs but i'm far from an expert. I plan on getting someone in to do the job and just want to get things in order first.
Many thanks in advance!
Mark :bucktooth:
The motion sensor you refer to is often called an occupancy sensor. You could run the lights, the mirror heater and the fan all from the same occupancy sensor. There's lots of different ways of dong what you want, a lot of it depends on your existing electrics and the general layout of things so I'm sure the electrician you get in will come up with the most suitable solution for your particular bathroom.
what about people like me who shower every xmas , whether i need one or not.
and don't mistake the blender for a bidet.
Reply to Automated Bathroom Advice in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Got an awkward bathroom fan installation in a downstairs flat, concrete ceilings and (some) walls. Bathroom is already fully tiled and...
Hi, my niece lives in a flat and has a bathroom without a window. There is an extractor fan which packed up and an electrician installed a new one...
Hi, Some advice would be appreciated… I have 4 downlights in the bathroom and want to add a motion sensor to turn on just one if everything is...
Hi All, I need a bit of advice. My client is asking for a rather silly lighting setup in his bathroom and I am struggling to understand...
Hi All I have recently had a new bathroom mirror installed with a built in LED and Demister that is turned on using a motion sensor. The mirror...
