Discuss Ballast wiring??? in the Electrical Forum area at ElectriciansForums.net
i=p/u
If you wire a ballast incorrectly , would it damage it?
I got a 2x 42w ballast today and the numbers are different on this one.
What does the wee star indicate on the Ballast wiring diagram?
Any help need more info just ask thx.
1,2 has the we star which was neutrals
3,4 was line's
5,6 was neutrals
7,8 was line's with the wee star
Hmmmmm
And the new ballast has 10,11,12,13,14,15,16,17 with wee stars between 10,11 and 16,17
Hmmm I'm probably over looking this but the ballast cost £80
Most ballast are straight forward, if they have the same number of connections. The diagram will usually show all wiring to lamp holders, and the stars need to go to the nearest lamp holder(s) as they need to be as short as possible.
The only problems that can usually be encountered, is when the lamp configurations are different (eg: in series, and lamp holders are connected together rather than direct to ballast).
Some ballasts can run with either multiple series smaller tubes or standard configuration with a single larger tube. I'm wondering if the asterisks or stars indicate different wiring schemes. Assuming the incoming supply was not incorrectly connected I would imagine that it wouldn't be damaged by mis-configuring the outputs if it's a recognised brand name item. Some ballasts have a lockout feature to prevent fires or ballast damage when a fault is detected or when the tube reaches end of life. Often powering off will reset but there may be another manual method of resetting required. I would be heading for the manufacturers website for a data sheet.
3,4 was line's
5,6 was neutrals
Hmmmmm
From that small amount of info, I would guess that 10-13 would connect to one lamp and 14-17 would connect to the other.
10-11 and 16-17 would connect to lamp holders nearest the ballast.
Just check the lines on the wiring diagram, and ensure the wires connect to the correct side of the lamp holder as they may be crossed over which is prevent the lamp from striking.
why do they need to be short as possible?????
a guy i work with told me it doesnt matter as long as you match the browns from one lamp with the blues and yes the astrix means the shortest ... so not loads init and its up and working and everyone is happy. ty
3,4 was line's
5,6 was neutrals
Hmmmmm
After a quick look at most of the ballast's, my conlusion is this:
1,2 (*N) into - 10,11 (shortest cables)
3,4 (L) into - 12,13
5,6 (N) into - 14,15
7,8 (*L) into 16,17 (shortest cables)
That should work as for your dimming is it controlled by a LCM or just a standard 240v dimmer?
It's a touch dimmer. The ballast also has perm live and switched live. I got it sorted/working and have learnt a bit. Ty
I have no idea, other than the instructions say so.
3,4 was line's
5,6 was neutrals
Hmmmmm
80 quid for a ballast that must be a typo right?
Reply to Ballast wiring??? in the Electrical Forum area at ElectriciansForums.net
