Discuss Balluff Rotary cam switch in the UK Electrical Forum area at ElectriciansForums.net
Hello to everyone. There is an inductive sensor to control the angle on the "Balluff bsw 819" rotary cam switch in a 1000 ton mechanical press. However, the part where the sensor was attached was broken, they replaced it with something else, the original is missing and the part code etc. in the technical document material list of the machine. does not exist. Balluff, on the other hand, said that the piece was not his own production. Where can I find a sensor attachment apparatus that I can attach such an angular adjustment to?
  • sensor.mp4
    5 MB
Reply to Balluff Rotary cam switch in the UK Electrical Forum area at ElectriciansForums.net
Greetings! I'm looking some exploded views of the N20, N40 and N80 rotary cam switches from Telux (Benedict & Jäger). Some of my customers tried...
Eh up :) Installed a set of "Quinetic" kinetic wireless switches and receiver today, in a situation where the landing light L was fed from the...
53K
Squid
My customer read on many forums about people suffering to solve a problem with the above Land Rover with regards to a fault code known as P1260...
29K
P
Hello everyone, I would like some advice regarding some work that a contractor has performed on my flat. I live in a block of flats where major...
8K
Please take some time to read through this. It is written by Widdler's father. I found it on a governement website.. It certainly speaks my mind...
