My exact model is here. I dread paying £130 for a bathroom extractor fan. It doesn't really seem to be all that different from something like this. I was thinking about getting that, attaching a reducer for the duct, and then getting some sort of trim to go around. Any thoughts on this?
I did warn you they are expensive ............................
Try and do it any other way and it could easily end up looking like a dogs dinner ........... and not extract very well....
trying to understand current building regs. atm. you stuff in tons of insulation to keep the heat in, then fit humungous fans to suck it out. confused.com.
Centrifugal fan are better then the standard fans as the airflow rates are usually better I have Airflow fitted in my bathroom.
If you are worried about the noise then fit a Sonos system and a single stereo speaker to muffle the noise of the fan and anything else.........
What distance is it extracting over ?
Honestly I'm not sure. I'm in an apartment block, so it's hard to tell. If it's going to the roof, then likely 1 floor up. After some searching, I'll probably get this centrifugal fan.
I think you are making a big mistake. The likely hood of the replacement connecting to the existing outlets is unlikely at best, not at all at worst.
C’mon OP!!!! You have asked for and been given very good advice. Given the location and length of extract duct, you will be wasting money by fitting anything other than a direct replacement.
Deleted member 108834,
polo1,
