Discuss Bathroom extractor switch in the DIY Electrical Advice area at ElectriciansForums.net
Ahm
Hello
I have changed the switch for my bathroom fan extractor.
The first picture is how it was initially wired. The 2nd pic is of the old switch. The 3rd picture is how i have i wired the new switch. The issue is there is electric current in the outter screw when touching with a tester. Is this usual? Or have i messed up?
Thank you for your help
Ahmez
@OP. youse has made a complete and utter bollox of a simple job.,using the wrong switch and wiring it up as a pig's arse. only way out is to get a local sparks in before you kill your family.
we always try to please, or pee to trise.
Think you’re holding back a bit there Tel!
that's OK. been grafting all day only firing on 3 cylinders till the jack daniels kicks in. got to be crafty though . back work tommorow.
Had the cash to buy an MK DP switch but not the cash to pay an Electrician to fit the correct triple pole isolator.... Let me ask you OP do you change the boiler when its knackered?
That is not a triple-pole isolator, you have connected live conductors to the earth terminals. As the switch is not earthed that is a seriously dangerous situation.
Thank you very much Westward10, just put the old switch back.
...direct to the point....cheers.... have removed the new switch and will get local sparks instead
Reply to Bathroom extractor switch in the DIY Electrical Advice area at ElectriciansForums.net
I've installed a replacement bathroom extractor fan. Pic on the left is the old one. Pic on right is the new one. Wired the same way but the fan...
HI There, I would be grateful if you could help me, I have a very long duct between the bathroom and extractor outlet vent and for sometime, the...
I’m replacing an old 100mm extractor fan in the kitchen with a new one. The old one was a pull cord fan whereas I bought a timer one (no pull...
Hello, I'm swapping my extractor fan in the UK and I have bought a Turkish extractor fan stupidly and the connections you can see in the picture...
Thinking a 240V AC relay activated by two independent light switches could be used to switch power to a shared inline extractor fan. The fan...
