Discuss Bathroom light switch in the UK Electrical Forum area at ElectriciansForums.net
Doomed
So we are refitting the bathroom and the wife does not want a pull cord anymore.
The only contact IP rated switches I can find are low voltage or battery wireless ones that are suitable for a bathroom both of which may be fine for the moment, but I just dont fancy the long term possible faults (as there will be receivers and or relays in the ceiling void which will be sealed and not accessible after the completion).
Has anyone come across an IP rated, preferable 2 gang bathroom wall switch?
Do you have any photos of where you want to position the new switch? It may not need to be 'IP rated' if it is a suitable distance from the edge of a bath or shower.
Install the switches outside the Bathroom, never heard or seen a 2gang Bathroom Wall Switch either.
are you fitting downlights...if so you can put a reciever in ceiling void next to light and it will be accessible......have a look at the Quinetic range from TLC....wireless switches no batteries you can have them on the shower screen if you want
About 1m, I would be happier IP rated
[automerge]1578744304[/automerge]
We have annoying children, outside the bathroom is NOT a good idea.
My wife is an interior designer, she has odd ideas sometimes.
[automerge]1578744456[/automerge]
Have done that before for clients, was just worried about access afterwards
the reciever will fit through the cut out for the light
Most light switches can be positioned inside a bathroom, but is depends on where wrt where the shower/bath etc are located.
As Freddo asked
Give us an idea of the layout, all you may need is a standard 2-gang light switch.
A standard switch might be suitable!
If you want/need IP and don't want a bulky outdoor switch on your wall, have a look HERE for touch switches that can be placed behind tiles and other surfaces. I have fitted a few and they work really well.
Doooohhhh, does anybody on here other me, actually read what other people have actually already posted. :mad:
haha.. I didn't spot @Markyd post #5. I really thought that no one else had mentioned it.
If I recall @Doomed is a competent sparks. He's just asking if we know of a suitable product.
I like the term competent, thank you :)
[automerge]1578783404[/automerge]
This is interesting, not for me, but will tab that site for reference
Reply to Bathroom light switch in the UK Electrical Forum area at ElectriciansForums.net
Thinking a 240V AC relay activated by two independent light switches could be used to switch power to a shared inline extractor fan. The fan...
I have 16 ceiling spots to be replaced in a room being repurposed as a bathroom. Some will be over a shower, basin and bath hence need to be IP65...
Hello, I currently have two switches in my bathroom. One controls the lights above the sink and the other controls a light above the toilet and...
Hi all, wonder if someone can help me. I've bought a bathroom extractor and I do have the wiring there already (previous extractor was there) but...
