- Apr 20, 2010
- 413
- 45
- 103
- If you're a qualified, trainee, or retired electrician - Which country is it that your work will be / is / was aimed at?
- United Kingdom
- What type of forum member are you?
- Practising Electrician (Qualified - Domestic or Commercial etc)
As usual, a problem arises nearly last thing on a Friday!! Was wiring a kitchen for someone this week & the customer noticed this afternoon before I finished there was no hot water. Central heating is working fine. The back of the programmer shows it as fully pumped on the selector. Getting no power at the cylinder stat, thought it was maybe the programmer so linked it out & still nothing. Had a quick look under the floor, can’t see where the cable goes but have found the pump. Should there be a mid valve somewhere? Can’t see one anywhere near at all. No sign of a JB under floor either. All I can see is cable that goes to pump from the programmer & cable that goes to baxi from boiler.
