we have been using Aurora, clips are good on them but I think you will find its more a case of what looks good for you, they will all have to come up to the same standard to comply
I switched to using the Aurora ones about 5 or 6 years ago and haven't changed since then. Plenty of options, styles and finishes, see link to bog standard low voltage fire rated option
Never really had a reason swap away from their Transformers either AU-E60 is very reliable although more using the the AU-PD60's now but they do some reasonable 'budget' versions too.
They are not the same link, don't know why they look the same.
