Looks like a lot of effort for one CAT5...
However I can see the advantage when pulling in multiple cables, one job we had involved over 50 on a single run, that would have been very handy.
we had about 200 metre runs of about 70 2.5 2core swa , 3 scissor lifts, 7 boys pulling and attaching ropes etc, plus brute strength, also we were about 30 metres in the air, worst cable i had to pull in was an 84mm 5core, 500 odd metre run, just 3 of us through a fish factory loft space , over and under all the obstructions, we had rollers but easier to just drag it into place
There's rollers, and there's sexy rollers. I like !
they are a bit gimmicky though, our boss bought rollers but he had too much money when compared with levels of sensibility, nobody on site used them because of hassle of setting them up and retrieving them, making sure cables dont slip off the rollers is also a bit of an arseache
I've done lots of cable pulls that would not have been possible without rollers though. Sometimes even just for moving the cable across a floor. If the cable is big enough to need a roller, it is usually heavy enough to stay on the roller.
Usually this type
Usually this type
until you have several corners to navigate and keep the cable tight so it doesnt slip off, if youre working alone these will save you but if youre in a squad many hands make light work
An example of what I mean. This poor short arse bugger I used to work with wouldn't have stood a chance pulling this in above his head.
(identity protected due to colleague being in witness protection programme after p*ssing off a bunch of joiners one time)
get him a toolbox to stand on, i love being over 6 foot tall, makes zs testing so much easier, then again squeezing into DB cupboards it becomes an issue, swings and roundabouts.
rollers are ok to use in like that, but when you involve going round beams and the rollers are vertical, keeping pressure onto the cable so it doesnt fall off really grinds my gears, i cant even use my anger to just rug the cable with big heaves from everyone to shift it when it gets jammed on the rollers
Pete999
Northampton
Retired Electrician
Business Name
None
Big cable tray pull to do you might like this vid then
Pete's Videos
Pete999,
elsparko,
