B
BMelectrics
hello all,
came across a strange one today.
I was told that a motorised valve would not close so was asked to check it out.
When I was checking how it was wired, it is the type that requires a common, open and close.
When I checked the stats wiring that was controlling this valve, the connections were: live, nuetral and call.
What I noticed was that the thermostat was being used like a 2 way switch! The live was used as the common, the NEUTRAL was used as the 'close' for the valve, and the Call was used for the 'open' of the valve.
I slapped my meter on the connections at the valve only to find that when the valve was 'opening' i was only getting 190v between the 'open' connection and neutral.
The person that wired this before done it so that when the stat is calling for heat, the valve will open slowly, but when it is not calling for heat, the valve struggles to close!
The stat has a relay in it and requires a neutral, so im wondering if this is messing the whole thing up??
thoughts please???
This is killing me!
thoughts please???
This is killing me!
