Discuss boiler cross bonding in the UK Electrical Forum area at ElectriciansForums.net
*points*
There! That one over there!
*runs and hides*
Yes ..... Quite thank you. :)
The fact is that all the pipe work is bonded by means of the tap rail which it's fixed to so whether we like it or not it is already bonded by default - a fact that the idiots at British Grasp and others seem unable to understand.
Its not required in the electrical regs , its one thing that was done because it looks pretty , even to 16th edition , but supplementary bonding was required as has been said in special locations also if you look at the main bonding for a gas pipe under plumbers regs they say it should be within a meter of the gas meter again not an electrical reg, as with alot of manufacturers they add requirements with out consulting the regs , look how many bathroom lights still have zone 3 on them
One of these is spelled incorrectly. Do you know which one - and what the correct spelling should be boys & girls?? :)
oh if your going to be like that shouldn't this be spelt :stooge_curly:
Errrr ........ no, not really. :)
[h=2]Spelled and Spelt[/h] The verb to spell most commonly means to write or name the letters that form (a word) in correct sequence.
To spell is one of those verbs with both an irregular form and a regular form. (See the table below for some others.) The past tense and the past participle can be written as either spelled or spelt. However, they are not interchangeable, especially in the US. [h=2]Americans Demand Spelled[/h] In America, spelled dominates. The use of spelt as the past tense or past participle of to spell is considered a spelling mistake by many. It will certainly annoy a fair proportion of your readers. [h=2]Brits Prefer Spelt[/h] Outside America, spelt is more common, but spelled is generally accepted. (This is almost certainly a result of American influence spreading.) [h=2]Misspelled and Misspelt[/h] It's the same with misspelled and misspelt. Americans demand misspelled (and Brits will accept it). However, Brits prefer misspelt.
Read more at http://www.grammar-monster.com/easily_confused/spelled_spelt.htm#RfJiArpV4d0TuTtZ.99
Today I am wearing my American head. :cowboy:
Spelled and Spelt
To spell is one of those verbs with both an irregular form and a regular form. (See the table below for some others.) The past tense and the past participle can be written as either spelled or spelt. However, they are not interchangeable, especially in the US. Americans Demand Spelled
In America, spelled dominates. The use of spelt as the past tense or past participle of to spell is considered a spelling mistake by many. It will certainly annoy a fair proportion of your readers. Brits Prefer Spelt
Outside America, spelt is more common, but spelled is generally accepted. (This is almost certainly a result of American influence spreading.) Misspelled and Misspelt
Read more at The difference between spelled and spelt (grammar lesson)
Yep, Geordie Obama does have a certain ring to it!! :92:
I was in NAPIT once. My assessor went all philosophical on cross bonding boilers, he knew his stufff better than most but just told me to "just do it" as it will take less time having to drive back/ explain to the plumber / explain to the home owner. As it won't make any difference (except to save oneself time and annoyance trying to explain why the sky is blue)
I can understand his point completely.
The trouble with complacency is that the lunatics will eventually take over the asylum.
From my reading of this forum for the last few years, I think they're half way there.
Reply to boiler cross bonding in the UK Electrical Forum area at ElectriciansForums.net
Greetings, I am homeowner and looking to confirm if I will need earth boding to water pipes. There is already earth boding near Gas meter and the...
Calling all electrical professionals / boiler tradesmen -WE NEED YOUR HELP! Every so often (twice in the last two days) when running the hot...
No waffling, going to get straight to the point. Main water on the exterior of the building in plastic. Changes to copper inside the building...
Hi, I'd like to move the existing socket that feeds the boiler down to where I've pencilled in that can be seen on the photo. The socket to the...
Do you need cross bonding. Main gas and water incoming is plastic and all circuits are on RCBOs
