G
Guitarist
I've recently wired a boiler frost and pipe stat from the permanent live of the 10-way control centre which is supplied via an SFCU fitted with a 3amp fuse. However, the heating engineer on site has told me that it should be from a supply which has nothing to do with central heating, so that it cannot be accidentally switched off when the boiler is isolated. I did explain that this would result in 2 supplies at the control centre, and provided that the sfcu is labelled to warn against accidental isolation, it is better to have the whole central heating system isolated by one source. Your views would be appreciated.
