This thread uses a prefix to highlight that the thread involves something central heating related. Try to use prefixes more often peeps.
Today our boiler kept running despite no demand from the (new) honeywell T4 Thermostat in the hall. The room temp was 23°C with a thermostat set point of 17°C. This is at least the second time that this has happened.
We had a technician from the boiler manufacturer come out. He fitted a RC device on the boiler across the feed from the 2 port zone valve.
This has not fixed the problem. I am prepared to fit a new zone valve if this will solve the problem.
Unless you guys have a better idea.
Thanks in advance
if its been determined that the room stat is NOT calling for heat, then it possibly is the motorised 2 port valve at fault. Check that the manual override lever hasnt been hooked on... If thats ok, give the valve head some small taps with a hammer to loosen it off.
Im surprised that the boiler technician couldn't diagnose it
