Discuss Bonding of 2 gas pipes in the UK Electrical Forum area at ElectriciansForums.net
Not silly at all. You have simply exposed what can be a very real vulnerability in any electrical conductor (not just a bonding conductor). This is where the often underestimated "visual test" comes in to its own. And the electrical reality is that our meters and testers have their limitations.
Your eyes tell you quite a lot, in some situations still like to use my analogue meters like to see a moving needle.
Back when I was a student called the gas board in because of a smell of gas (which the landlord denied and said he had it checked).
He really did light a lighter and ran along the pipe until he got a little gout of flame from a tiny tiny hole.
He then condemed every gas appliance in the house (much to the landlords annoyance)
we had a leak , BG capped off the tee into the house ( hob and unused gas fire just leaving feed to boiler in garage, don under maintenance plan so no charge. ). my mate the plumber then tapped off the the boiler feed to re-feed the hob, that cost me 3 pints of ale. winner.
a gas engineer would expect to see the bonding within 60cm of the meter
Looked at a job recently where a gas engineer had advised the above as a 'non compliance'.
The meter is external to the property (small block of flats) but incoming gas service pipe (copper) to the flat (second floor) has been bonded within 600mm of entering the flat. (Not easy route from internal service cupboard to ground floor meter!).
There doesn't seem to be a 3 tier system like the EICR to determine compliance (saftey) with the gas report but I advised the landlord from an electrical pov, it would be C3 at worst which is declared 'Satisfactory'!
(The recent EICR was just ticked!) The LL will take up the issue with the gas engineer/company.
Agree?
Agree?
Something that bugs me is that the bond is an "electrical" safety requirement. So if the electrician deems the bonding to be compliant with the current regs, why do the gas monkeys and meter readers think they can override this?
Reply to Bonding of 2 gas pipes in the UK Electrical Forum area at ElectriciansForums.net
I know once you see plastic entering then you don’t need to bond as it says on site guide.(enters the house plastic then it’s metal) Would I be...
evening everyone . Quick question here I’ve recently took over a job that a friend of mine first fixed it’s a 3 bed semi house rewire. I don’t...
Hi, went to have a look at a job today, customer has had gas supply company out (for another issue) and they have commented that the protective...
Curious about supplementary bonding, I have these two 4mm Cables loose and not connected to anything in my parents house. I presume they are for...
Does a copper gas pipe, coming into the house require bonding when the pipe is being supplied by propane cylinders, via rubber hose. Doesn’t go...
