Discuss Brass ip65 adjustable downlight in the Lighting Forum area at ElectriciansForums.net
Don't get too excited, the adjustment isn't huge and appears to be done by a lens change. I think you may struggle because of the IP65 rating
As per Andy, do you really need an IP65 fitting if it's under a porch roof.
You get shallow beam-angle MR16 and GU10 lamps which are 24/25 degrees instead of the usual 36 or 40 degrees. Maybe that might work for you.
If there's no roof leaks and they're not going to get direct rain or mist/spray then I don't see why a particular IP rating would be required.
IP33 is the minimum for an outdoor light but these are not really outdoors.
I have some IP44 eyball downlights (MR16 in PC) that I bought for a customer who then changed their mind. The manufacturer is not given but the downlight was called coniston. These where bought about 6 years ago though. I thought they were available in brass as well.
Reply to Brass ip65 adjustable downlight in the Lighting Forum area at ElectriciansForums.net
This weekend at Electrical2Go we are offering the Ansell Prism pro (APRIP/1) for just £6.95 ex VAT ! These are one of our best-selling...
Does anyone know of a product similar to the Integral LED 70-100mm range (linked) that allows you to adjust the lamp direction? The client has a...
When considering lighting options for your home or business, Electrical2Go provides a wide array of choices. Among these choices, downlights stand...
Hello, Does anyone know of a Driver for led tape that can adjust the brightness on the driver itself by turning a screw etc ? Just need...
Electrical2Go - Mega Downlight Deal - Don't miss out! Taking place from August 18th to 20th, we're offering an incredible promotion for...
