Discuss Breaker size for Double Oven. in the UK Electrical Forum area at ElectriciansForums.net
Your comments appreciated please:
New Neff Double Oven - 28A total load. Oven tail 4mm 3c butyl HO7 35A rated.
Feed 6mm T&E, to a 40A oven switch with 13A socket.
Circuit breaker - 40A or 32A ?
thanks,
John.
a 32A MCB would be my choice. this would be adequate for the load.
Yep would agree with 32a, might have been OK with 40amp if cable was 10mm2
Reply to Breaker size for Double Oven. in the UK Electrical Forum area at ElectriciansForums.net
We have a room in the house that was the kitchen. That has been relocated to a different area, so the old kitchen has been sold off and the room...
Hi all, Recently a mate had a new kitchen fitted, he's gone for an induction hob and pyrolytic oven, no gas at the property. At 1st fix a single...
4K
Hi Guys, I am just changing my plug top oven over & gas hob and noticed the following: 32AMP Breaker > 6MM Cable > Cooker Switch 45a > 4mm cable...
Howdy experts, I normally run 6mm T+E for cooker circuits, housing authority spec. I'm changing my gas inbuilt double oven and hob for...
Client currently has a DB in his outhouse. It feeds a pool pump and an air source heat pump. It is currently being supplied using a 4mm T&E cable...
