Seconded that it looks like wet getting in. Which could have aggravated a bad connection at the brown live connection. Yes refit a new plug and if there is an earth in the cable be sure to fit it. Make sure the fuse you put in is suitably rated for the appliance; post back on here with whatever amps (A) or watts (W or kW) the appliance says on its label that it draws and no doubt someone will recommend the most suitable fuse rating. For absolute top whack brownie points, when you wire the plug, make sure that the most slack is in the blue and (if present) green/yellow wires so that if the strain relief fails, the first one to break will be the brown. This is not a licence to go mad with the slack on the blue and green/yellow of course.
