davie a
Hi, I am looking for advice. I have a plug I opened only to find scorch marks in it. I never wired the plug as I got the appliance from my parents.
Cut the old plug off and fit a new one. The live wire was either too loose or over-tightened which caused it to overheat.
If when you strip the cable you find there's an earth wire then be sure to connect it in the new plug.
It wasn't working, parents said they thought it was needing a new fuse so just opened it to do that. Thanks for the advice.
yeah caus that looks suspiciously like a 3 core does that flex....
Great sharp photo. Yes I was just going to say it looks like wet has got into the plug as there's marks near the earth pin too.
Seconded that it looks like wet getting in. Which could have aggravated a bad connection at the brown live connection. Yes refit a new plug and if there is an earth in the cable be sure to fit it. Make sure the fuse you put in is suitably rated for the appliance; post back on here with whatever amps (A) or watts (W or kW) the appliance says on its label that it draws and no doubt someone will recommend the most suitable fuse rating. For absolute top whack brownie points, when you wire the plug, make sure that the most slack is in the blue and (if present) green/yellow wires so that if the strain relief fails, the first one to break will be the brown. This is not a licence to go mad with the slack on the blue and green/yellow of course.
on pic, cable clamp looks like it was rather tight too!
edit; just looked again, not on the flex. must get eyes tested!!
tony, i think OP was more concerned about why, not how.
I know why it was posted and I would have thought it was fairly obvious why it burnt. Just seems an odd thing to post.
If I took a photograph of every damaged plug and socket I’ve come across I could write an entire thread myself. Admittedly most of them would be down to cag handed plant operators.
Apparently you’re supposed to unplug a piece of kit before picking it up with a FLT and driving off, takes too much time to do that.
