Discuss Cable dammage by drill in the Australia area at ElectriciansForums.net
Chop the wall out,cut the damaged bit of cable out and use thru crimps,sorted.Make sure you stagger the crimps.Got a call today by a plumber and while drilling for pipe clips he went though a cable for a ring main what would be the best course of action to repair the cable in the wall.
Cheers all
We would try and pull a new piece of cable up the capping and use 30a j/bs.
Where do you intend to put the JBCrimps are classed as permanent connections matePersonally id chase the wall and run new cable with 30A JB's, crimps are not considered permanent connections so must be accessable for inspection
agreed but if you crimp joint then seal it it is permissable to put the joint in the wall where it is inaccessable.Sorry but crimps are not adequate on their own,all joints must be in a suitable enclosure and accessible for inspection. A short section of single insulated wire will be exposed,crimps do not fully insulate connections,so any dampness in the wall during or after making good could result in a voltage appearing on the wall. Crimps just plastered in the wall are not an option.
Hello Mac,
told by our assessor crimps are not perment connections but hey at the end of the day its all opinions, JB's above ceiling under floor boards - use armeg cutters of cut borad above or cut floor boards (but all depends on job which we havnt seen)
If the the terminatiion is made using an approriate compression tool (ratchet crimper) then it is a permanent connection abviouly you externeal influences have to be taken into account so putting them into a small box to prevent moisture then sealing in wall is ok
Johhny b would you have access to joint box?? you going to put an inpection hatch in kitchen??
sparks i agree if possible to replace the leg fine its the way to do it. However if that is nt possibel a crimped sealed connection in wall isnt a bodge either
526.3 iv - conseaded - however how would you explain away 526.5 ii - just curious so I have an answer for my next assessment
Yeh! i would,t bury my j/b,s i would have them where i could get to them in the future my friends, i think thats got to be better than burying stuff in the wall hoping it will never breakdown.
JBs need to be accesible,not buried.What happens when the next spark comes along or its buried behind a cupboard or tiles.Do you put a notice up,access needed,electrical connectionAs scotsparky posted.Yeh! i would,t bury my j/b,s i would have them where i could get to them in the future my friends, i think thats got to be better than burying stuff in the wall hoping it will never breakdown.
Sorry mate,apologies.It wasn't worded properlyMac, if yer read my post it says i WOULD,T bury my j/b,s
Reply to Cable dammage by drill in the Australia area at ElectriciansForums.net
