Discuss Cable end box in the UK Electrical Forum area at ElectriciansForums.net
R
RichardTM
Hi
Sorry I don't know if this is the right section but I have a question.
I need to know how to terminate PVC cables (up to 1200volts insulation) for entry into cable end box using mechanical and compression methods?
Thank you
Thank you
Yes this is a college question they told us to google what we don't know and I dono what I googling is right
EDIT: If you asking because you think its a test or assignment question, just so you know its not. Im busy with a practical course and i have to make summaries of a lode of stuff like diff ways of fault finding and definitions of resistors, capacitors and lots more this cables question was one of them. :)
Ah ok I see, seeing the actual thing helps, thank you. Summary done :) The lecturer probably wont check it like usual but any way.
Thank you again you may lock or set this topic ad resolve :)
Reply to Cable end box in the UK Electrical Forum area at ElectriciansForums.net
Hi I've inherited a very tight space, a KMF switch and some split-con for a sub-main to try and tidy up. It's a joyous non-restrained single...
Hi. Im looking for some advice when calculating submain cables. Basically there is a new connection of 80Amps that is to be used for a dwelling...
Hi, i live in a new build house where they builders have left a junction box on the outside of my house. In the junction box there is a 6mm twin...
Hi all, it's been a while since I've been on, apologies. I am debating whether I need to replace the bonding to the gas meter. The meter is...
