S
shaunus4
HI,
I can't seem to find any cable rollers/runners anywhere, is there a specific name for them?
You know that yellow folding nmetal one with the metal bar or even theplastic one that clicks together!
Made by thorsman and called 'cablestik'
Oh well, that image didn't work but google Spooler cable carrier. TLC do one along with a few other wholesalers.
or try this: ebay item no. 140682594009
I have the cablestik by thorsman. It's good and holds a lot, but a little heavy and bulky especially for domestic situations. Depends on what you need it for. It's great if you are running a lot of singles off to go in trunking.
2 angle boxes
4 equal lengths of 20mm conduit
a 25mm hole cutter
a 1m length of 25mm tube
2 flanged couplers
2 25mm bushes
job done!
apprentice and broomstick. (when the m-i-l ain't using it)
OK guys, here is your answer Cabro Eaziroll Ltd - Home not the cheapest but certainly the best, features a free running feed roller as opposed to the fixed bar method, which causes cables to tangle and also an adjustable cable guide bar.
2 angle boxes
a 25mm hole cutter
2 flanged couplers
2 25mm bushes
job done!
As above, but instead of 4 equal lengths of 20mm conduit, make 2 a couple of inches longer than the other 2.
This will raise it slightly on one side as you look at it and thus keep all the reels down at one end reducing snagging.
