uksparks
- Reaction score
- 1,228
What he said.
Its totally over kill and pointless to run conduit inside, there's loads of basket, so why not use it.
Discuss Cable size in the UK Electrical Forum area at ElectriciansForums.net
What he said.
Then don't make a mess of it, it's drilling a hole through a wall, if you can't manage that without making a mess then???
I wouldn't entertain jointing a 16mm SWA in a plastic box personally,
EV Charger.
Tricky as only you have seen it. I can see the sense in what davesparks is saying, if you can avoid a joint its always better to.
Have not got time to read in full but check reg 722.411.4.1???
PME earthing shall not be used as the means of earthing for the protective conductor contact of a charging point located outdoors.
It goes on for a bit but need to go home. Section 722 of the new regs book. Page 279.
Have you chosen to accept the mission
it is part of a three phase supply, so I guess I don't need a rod.
Why are some regs so confusing.
Reply to Cable size in the UK Electrical Forum area at ElectriciansForums.net
