U
uksparks
Care to explain how being a three phase supply removes the need for a rod?
Sorry I meant to add, if it was a dwelling....
I took my reg from the latest amendment. Are your examples from an older regs book? Things may have changed?
I take it you didn't pay any attention to what was new in Amendment 2 then?
You really aren't on the case at all, are you?!?!?!
green is amendment 1 and yellow is 3I am sorry. I don't understand your point.
if thats what has changed in amendment 3 you can follow either edition till July, ill have a look through mine when it arrives tommorow (BYB)So going back to post #43, this was taken directly from AMD 3.
To me this says I DO NOT need to put a rod in. Whats your take on it?
My take is that you cannot use a PME connection unless one of the three points are satisfied.
Without knowing more about (i) I wouldn't like to make any assumptions.
The device required to comply with (iii) isn't on the market yet I don't think.
(ii) is pretty easy to comply with if you wanted to, all you have to do is get a decent earth nest installed and connected to the MET.
A little beyond my ( in my head ) knowledge this is but I do think Dave seems spot on. If there was doubt though I would recommend an earth rod. Save on the extra core then. Just don't forget to CAT scan first.
Where did you get your BYB from? I was just looking on Amazon and they are out of stock.
I have not got the BYB yet, but have a copy of AMD3.
Looking at (ii), I did read somewhere that the resistance must be very low, something like less than 3 ohms maybe, does anyone have any clarification of this?
