darcybobs21
Hi All,
Can someone please help me with calculating the cable size of a 50kw 3-phase Ac supply over 35m, on cable tray using swa? Just need to know the cable calculation as im getting confused.
Regards
Volt drop for solar should be no more than 1%.
Volt drop in volts is mV/A/m * A * m / 1000
Calculate your amps from I = P / V or I =
Distance is 35m
mV/A/m values are given in table 4D4B in BS7671
