Discuss Can a bulb trip the fuse in the UK Electrical Forum area at ElectriciansForums.net
sumith
I have a bulb that causes the fuse to trip. Had it for a couple of years, make is Diall. Maybe it's dead now, but I don't understand why it trips the fuse. I did a continuity test and it fails.
is it an old fashioned filament lamp?
If it has blown, then continuity will fail.
If its a halogen filament lamp, it may blow spectacularly.
Is your "fuse" an MCB or an RCBO? The RCBO is much more sensitive and will trip if a lamp simply burns out.
The problem could be with the wiring! Relieved to know. It was an led lamp. The fuse is rcbo. The replacement worked just fine, hence suspected the bulb. Since then, the tripping happened again. So I took the bulb out and even without the bulb, when switching on it trips now! But nothing has changed on the wiring. It was new 2 years ago. I inspected the switch and ceiling rose, it's all dry.
Reply to Can a bulb trip the fuse in the UK Electrical Forum area at ElectriciansForums.net
Two questions: 1. I’ve had a bulb in the hall turn black with some white powdery deposits (see photo), whats caused this, guessing i should get...
I have an issue with a home lighting circuit 6A RCBO provides power to 13 bulbs which randomly keeps tripping, when I say randomly it keeps...
Hello, Is there an actual age limit on house wiring that would prevent a traditional fuse box being replaced with a consumer unit please...
Hello I have some decking lights which to be fair, have been nothing but pain in the bottom since they were installed. Moisture in the lens lamps...
