L
lordyjordy
hi lads
regarding the image can i jack of the back of this and feed a surface mounted double pole switch for a shower pump?
cheers
i'd say no.you need to come off a socket via a FCU. think you need an electrician.
with a 3A or a 5A fuse. whatever the pump manufacturer's instructions specify.
oh ok
MI'S in the pump book say a double pole switch???
can you get fused double pole switches
yes a double pole FCU would do the job. if the pump is in a bathroom, then RCD protection must be provided, either at the CU, or by means of a RCD FCU. as said. get a local spark in. you pay for his knowledge and doing the job right.
ok any ideas on price, would you have to run cables from the consumer unit to the airing cupboard...
the only electrical device in the cupboard is this timer???
any way cheers
impossible to say, but should be a simple job to spur off a local socket. cost should be under £100 if it's straightforward.
