Bright white and chilled orange settings on it?
Is there not just another board same size that fits?
yeah it floats through a few colours but I dont have another board. I only have this light - can you expand more on what you mean by another board - Im just a DIYer
If, once turned on, you turn the power off does it come back on at the same settings as before the next time you switch the power on?
Yes it does , it holds last settings but Im not fussed with this, I use home assistant and its powered from a smart plug I work from my phone/automatons so just need to on/off from the smart plug.
If you don't need the sensor at all then just snip the wire off at the PCB.
The reason I asked about it holding it's settings is that if it doesn't then snipping the wire off could leave it not working at all.
So as it does hold the setting you can turn it on with the sensor, then switch the power off and snip the sensor wire off, then when you turn it on again it will still be working.
The CM connection that has a copper pad at the end needs human body charge to switch on (and off) I don't see what removing this wire will do - I still need to bypass it in order when the light gets mains power then it just lights - bypassing the CM touch on.
apologies in advance If I am not grasping your assist.
It's difficult to suggest any modification without a circuit diagram of the board.
One option would be to mimic the action of touching the switch when the supply was turned on.
Given you have the usb 5V available, you could add a timer module, maybe set for 1 second or under, with its relay COM and NO contacts connected between say 0V and the CM pad. Alternaively use a 470pf capacitor and 1 Megohm resistor in parallel in that connection.
Timer module here (if there's room for it!)
As an Amazon Associate we earn from qualifying purchases.
You said it remembers the last state it was in ?.
If that's the case, then if the last state was ON and power is removed, it should revert to its last state which was ON when power is reinstated.
Unfortunately it needs that voltage shift to turn off and on but it does remember the setting/colour it was before.
I know pin 4 of that big chip is in and legs 9-16 is all about colour etc.
Chat gpt suggested soldering a resistor and cap from 5v to pin 4 then from pin 4 to 8 (gnd) with the other. But I took this with a
pinch of salt
pinch of salt
You would have to measure the change at that pin so as to know what it’s doing when the pad is touched.
It maybe worth looking at the IR remotes input to that chip.
The chip is undoubtedly a micro with software dedicated to control everything.
The input to the micro is probably going to be held low and taken high to change states.
Post a pic of the other side of the pcb if possible.
