Discuss Capacitor Issues in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
mackos
I have a Hayward pool pump where the start cap is 161-193 uf. How can you have a range of capacitance. Hayward is an american company. so maybe it can run on 110v or 240v. (just a guess). The other issue is ceiling fan caps, now these are start/run caps and I know from past experience that you can burn out the motor by fitting too high a cap eg was 2.5uf only had a 3.0uf in stock (goodbye fan). But yesterday I had a 1.8uf bad cap & fitted a 2.0uf . The customer is now saying that there is a smell when on high speed. Why are the ratings of fan caps so critical when on other induction motors ie pumps,washing m/c motors you can fit 30uf instead of 25uf with no ill effect.
Thanks Mack.
Reply to Capacitor Issues in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
I have a Hayward pool pump where the start cap is 161-193 uf. How can you have a range of capacitance. Hayward is an american company. so maybe it...
I posted a month ago regarding a single phase motor + panel I have been given to try and sort following water damage to the panel. The assembly...
I picked up a 7.5W 110V TEFC single-phase induction motor for super cheap. I may use it on a home made lathe or stationary-sander for my woodshop...
I'm looking at a German made roller conveyor system 10 motors contactors controlled by a PLC Issue is customer says 3 mths ago motors started...
Hello.After my last posts about wiring of the two caps on my metal buffing/pollishing machine its been working great doing sterling service nearly...
